Internet Traffic Through ACE
Answered Question
Nov 19th, 2008
I'm having trouble getting to the internet on the servers in my server VLAN. The SLB is working correctly, the servers can get DNS queries and access other things within our internal network but I cannot get out to the internet. Do I need to setup some kind in inspection to pass normal internet traffic for those servers or how do I make that work? THanks
Correct Answer by Syed Iftekhar Ahmed about 8 years 3 months ago
You need to apply
service-policy input NAT
under server vlan (vlan 151) not Client side vlan.
int vlan 151
ip addresss 192.168.151.176 255.255.255.0
alias 192.168.151.175 255.255.255.0
peer ip address 192.168.151.177 255.255.255.0
no shutdown
int vlan 181
ip address 192.168.181.5 255.255.255.0
alias ip address 192.168.181.4 255.255.255.0
peer ip address 192.168.181.6 255.255.255.0
nat-pool 1 192.168.181.150 192.168.181.200 netmask 255.255.255.0
Syed
Overall Rating: 5 (1 ratings)
Syed Iftekhar Ahmed Wed, 11/19/2008 - 12:23
You simply need to allow server originated traffic through the ACE and Perform NAT on this traffic before it leaves your network.
Similarly for return traffic you need to make sure that the upstream L3 devices knows how to route return traffic back to ACE for server vlan.
Syed Iftekhar Ahmed
thefindjack Wed, 11/19/2008 - 13:00
I'm pretty sure its because I'm not NATing the traffic but I can't figure out why my NAT wont work. Here is what I'm doing.....
Client VLAN 181
Server VLAN 151
The servers are setup with the default route as the ACE's alias IP address on VLAN 151. The VIP is in VLAN 181, and the SLB works correctly. So I need to figure out how to NAT traffic originating from the SERVER VLAN. This is what I was trying but I couldnt get it working.....
access-list NAT_ACL extended permit ip 192.168.151.0 255.255.255.0 any
class-map match-any NAT_CLASS
2 match access-list NAT_ACL
policy-map multi-match NAT
class NAT_CLASS
dynamic 1 vlan 181
int vlan 151
no shutdown
int vlan 181
Correct Answer
Syed Iftekhar Ahmed Wed, 11/19/2008 - 14:21
You need to apply
int vlan 151
no shutdown
int vlan 181
Syed
thefindjack Thu, 11/20/2008 - 06:46
Thanks for you help! I got it working, you were right about applying that service-policy. I also had to add the NAT_ACL to VLAN 151 as "access-group input NAT_ACL".
