asa failover & SSL vpn license question
Nov 19th, 2008
with a failover pair, if you want to purchase an SSL license, do you have to purchase the same license for each one, or can they 'share' a license since only one will ever be active?
ajagadee Wed, 11/19/2008 - 20:56
Steven,
You must purchase license for each and every device that you want to enable SSL Feature. It does not matter if the chassis is in active or standby mode in failover, you need a separate license.
Arul
*Pls rate if it helps*
