Serial Interface Resets
Nov 19th, 2008
Many thanks to all who have helped sincce my router guy up and left...
I have one other pressing issue I need assistance on. One of our remote offices is connected to the main office via direct T1. I have been told applications consistently lose connection with our servers from users in this remote office. Here are the stats fom the remote office router's serial interface:
Remote Office Router: 2600
Serial0/0 is up, line protocol is up
Hardware is PQUICC with Fractional T1 CSU/DSU
Description: Wan to HQ
Internet address is 192.168.2.18/30
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
reliability 255/255, txload 2/255, rxload 1/255
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
Last input 00:00:00, output 00:00:01, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 127
Queueing strategy: weighted fair
Output queue: 0/1000/64/123 (size/max total/threshold/drops)
Conversations 0/41/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1158 kilobits/sec
5 minute input rate 3000 bits/sec, 2 packets/sec
5 minute output rate 16000 bits/sec, 2 packets/sec
74378626 packets input, 1848314845 bytes, 0 no buffer
Received 2961633 broadcasts, 7 runts, 60 giants, 0 throttles
10630 input errors, 3265 CRC, 6793 frame, 0 overrun, 0 ignored, 572 abort
61204959 packets output, 3853218004 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
5 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
Thinking it may just be their router, I see their routers serial interface has reset a number of times and has many, many drops. Out of curiosity, I checked our core router and saw the following:
Corporate Core Router: 2821
Serial0/3/0 is up, line protocol is up
Hardware is GT96K with integrated T1 CSU/DSU
Description: Wan to Office1
Internet address is 192.168.2.17/30
reliability 255/255, txload 3/255, rxload 3/255
Last input 00:00:01, output 00:00:05, output hang never
Last clearing of "show interface" counters 3d00h
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 3278
Output queue: 0/1000/64/3278 (size/max total/threshold/drops)
Conversations 0/31/256 (active/max active/max total)
5 minute input rate 23000 bits/sec, 6 packets/sec
5 minute output rate 20000 bits/sec, 6 packets/sec
387261 packets input, 115143728 bytes, 0 no buffer
Received 30332 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
487387 packets output, 371441638 bytes, 0 underruns
0 carrier transitions
This also shows drops from the branch office...
I am at a loss where to begin troubleshooting this, so I am here to humbly ask for your help....Thanks again for helping me learn!
ropethic Wed, 11/19/2008 - 14:01
  • Silver, 250 points or more
First let me direct you to the what the meaning of the output stats
http://www.cisco.com/en/US/docs/ios/12_1/interface/command/reference/irdshoin.html#wp1020497
The branch router looks okay. 126 drops for over 61 million packets is very good, as well inut traffic.
Less than 1% drops on core, however this is over 3 days. keep an eye on this one. The branch router counters never clearing since last router reboot.
Tasks to be completed:
1. Show log - this will show if serial up / down status
2. Clear counters on remote office router
clear counters interface s0/0
Post show logs output.
I would also check to see if you are running backups, virus updates / scans during the day to users in office. I have seen whole departments lose connectivity during scheduled backups and virus scans.
InTech1976 Wed, 11/19/2008 - 14:28
Many thanks, once again. I will review the link you provided. Here is the info you requested. (I have to split this between 2 posts since it is loinger than 4000 characters - the board maximum)
Branch Office Router's sh log:
boffice1#show log
Syslog logging: enabled (0 messages dropped, 1 messages rate-limited, 0 flushes,
0 overruns, xml disabled)
Console logging: level debugging, 227 messages logged, xml disabled
Monitor logging: level debugging, 0 messages logged, xml disabled
Buffer logging: disabled, xml disabled
Logging Exception size (4096 bytes)
Count and timestamp logging messages: disabled
Trap logging: level informational, 230 message lines logged
Core Router sh log:
Syslog logging: enabled (1 messages dropped, 1 messages rate-limited,
0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level critical, 0 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 69 messages logged, xml disabled,
filtering disabled
Persistent logging: disabled
Trap logging: level debugging, 71 message lines logged
InTech1976 Wed, 11/19/2008 - 14:31
Log Buffer (4096 bytes):
.0.131)
000033: Jul 7 09:29:29.647 Chicago: %SYS-5-CONFIG_I: Configured from console by bhaase on vty1 (192.168.0.131)
000034: Jul 7 10:12:23.881 Chicago: %SYS-6-CLOCKUPDATE: System clock has been updated from 10:12:23 Chicago Mon Jul 7 2008 to 10:12:23 Chicago Mon Jul 7 2008, configured from console by last on vty0 (192.168.0.52).
000035: Jul 7 10:12:23.905 Chicago: %SYS-6-CLOCKUPDATE: System clock has been updated from 10:12:23 Chicago Mon Jul 7 2008 to 10:12:23 Chicago Mon Jul 7 2008, configured from console by last on vty0 (192.168.0.52).
000036: Jul 7 10:12:24.073 Chicago: % Multiple self signed certificates in config
certificate for trust point TP-self-signed-2057303117 ignored
000037: Jul 7 10:12:26.430 Chicago: %PKI-4-NOAUTOSAVE: Configuration was modified. Issue "write memory" to save new certificate
000038: Jul 7 10:13:24.054 Chicago: %SYS-5-CONFIG_I: Configured from console by someuser on vty0 (192.168.0.52)
000039: Jul 7 10:15:22.676 Chicago: %SYS-5-CONFIG_I: Configured from console by someuser on vty0 (192.168.0.52)
000040: Jul 7 10:21:06.421 Chicago: %SYS-5-CONFIG_I: Configured from console by someuser on vty0 (192.168.0.52)
000041: Jul 7 10:22:41.297 Chicago: %SYS-5-CONFIG_I: Configured from console by someuser on vty0 (192.168.0.52)
000042: Jul 17 12:39:29.298 Chicago: %SYS-5-CONFIG_I: Configured from console by someuser on vty0 (192.168.0.55)
000043: Jul 17 12:45:12.877 Chicago: %SYS-5-CONFIG_I: Configured from console by someuser on vty0 (192.168.0.55)
000044: Aug 11 10:28:44.241 Chicago: %SYS-5-CONFIG_I: Configured from console by bh on vty0 (192.168.0.131)
000045: Oct 1 08:41:39.235 Chicago: %SYS-5-CONFIG_I: Configured from console by someuser on vty0 (192.168.0.50)
000046: Oct 1 15:12:55.821 Chicago: %SYS-5-CONFIG_I: Configured from console by someuser on vty0 (192.168.0.50)
000047: Nov 4 14:38:27.301 Chicago: %SYS-5-CONFIG_I: Configured from console by someuser on vty0 (192.168.0.53)
000048: Nov 4 14:38:27.621 Chicago: %LINK-3-UPDOWN: Interface Serial0/2/0, changed state to up
000049: Nov 4 14:38:28.621 Chicago: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/2/0, changed state to up
000050: Nov 4 15:03:44.214 Chicago: %SYS-5-CONFIG_I: Configured from console by someuser on vty0 (192.168.0.53)
000051: Nov 5 08:51:53.908 Chicago: %SYS-5-CONFIG_I: Configured from console by bh on vty1 (192.168.0.131)
000052: Nov 5 09:10:17.411 Chicago: %CLEAR-5-COUNTERS: Clear counter on interface Serial0/2/0 by bh on vty1 (192.168.0.131)
000053: Nov 5 09:14:18.207 Chicago: %CLEAR-5-COUNTERS: Clear counter on interface Serial0/2/0 by bh on vty1 (192.168.0.131)
000054: Nov 5 12:03:23.732 Chicago: %SYS-5-CONFIG_I: Configured from console by bh on vty1 (192.168.0.131)
000055: Nov 6 17:30:28.685 Chicago: %SYS-5-CONFIG_I: Configured from console by someuser on vty0 (192.168.0.50)
000056: Nov 6 17:31:08.450 Chicago: %SYS-6-CLOCKUPDATE: System clock has been updated from 17:31:08 Chicago Thu Nov 6 2008 to 17:31:08 Chicago Thu Nov 6 2008, configured from console by last on vty0 (192.168.0.50).
000057: Nov 6 17:31:08.478 Chicago: %SYS-6-CLOCKUPDATE: System clock has been updated from 17:31:08 Chicago Thu Nov 6 2008 to 17:31:08 Chicago Thu Nov 6 2008, configured from console by last on vty0 (192.168.0.50).
000058: Nov 6 17:31:08.662 Chicago: % Multiple self signed certificates in config
000059: Nov 6 17:31:11.190 Chicago: %SYS-5-CONFIG_I: Configured from console by someuser on vty0 (192.168.0.50)
000060: Nov 6 17:32:56.591 Chicago: %SYS-5-CONFIG_I: Configured from console by someuser on vty0 (192.168.0.50)
000061: Nov 11 13:30:37.873 Chicago: %SYS-5-CONFIG_I: Configured from console by bh on vty0 (192.168.0.131)
000062: Nov 11 13:31:12.290 Chicago: %SYS-5-CONFIG_I: Configured from console by bh on vty0 (192.168.0.131)
000063: Nov 11 13:31:46.378 Chicago: %SYS-5-
glen.grant Wed, 11/19/2008 - 15:23
  • Purple, 4500 points or more
Looks like buffer logging is turned off on the branch router so nothing will ever be put in the log on the router . I would enable buffer logging on that router so that you can see if anything funny is going on . Also when people happen to be complaining I would take a look at the utilization on that link , as you get near the limit it very well could start dropping packets. A T1 isn't much bandwidth nowadays . Most people have a lot more than that just to surf the net at home . It would basically take 1 or 2 people downloading something to suck up a T1.
conf t
logging buffer 16384 informational
end
write mem
stephenshaw Thu, 11/20/2008 - 08:28
Hi, input and CRC errors are typically the result of a defective CSU/DSU or actual circuit problem. If the router shows no log entries for the actual CSU/DSU you may need to involve the Telco to start running some loopback tests on the circuit to pinpoint where the errors start occuring in the circuit path. Hopefully, you won't need to replace the CSU/DSU card.
Steve
