pppoe enable in 12.4(15)T
Nov 19th, 2008
When using SDM to configure Cisco871, I have found I am unable to configure the pppoe encapsulation. I found the reason - the router rejects interface configuration command "pppoe enable" since versions 12.4(15)XY4 and 12.4(15)T7. Previous version can be configured using SDM without problem, and I could not test higher versions due to flash size. Have you similar experience?
mchin345 Thu, 11/27/2008 - 05:18
  • Silver, 250 points or more
PPPoE Client in Cisco IOS Release 12.2(13)T and Later Releases
In Release 12.4(15)T
The following commands are new or modified for this feature:
• pppoe-client dial-pool-number
This command was integrated into Cisco IOS Release 12.4(15)T and PPPoE client functionality was modified to support multiple clients on a single ATM PVC.
For further information click this link.
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t15/mpppoec.html
