How to create VPN in PIX 535 Multicontext environment?
Nov 19th, 2008
I have configured 2 PIX 535 firewalls in failover (Software 8.0) with multicontext configuration. There are 2 context created. It's running fine. However Crypto map and ISAKMP commands couldn't be supported on this. So it became impossible to create VPN. Pls suggest.
cpembleton Wed, 11/19/2008 - 19:18
  • Silver, 250 points or more
That is one of the downsides of running multiple contexts. No VPN capabilities.
Don't use multiple contexts or use some other hardware like a router or fwsm.
Chad
Farrukh Haroon Wed, 11/19/2008 - 20:07
  • Red, 2250 points or more
Hello Pankaj, currently VPNs,dynamic routing,QoS etc. are not supported in multiple context mode. You have to either use single mode or find another device to terminate the VPNs.
Or find a gun to shoot the ASA coders :).
Farrukh
