ASDM cannot be loaded. ver 6.1
Nov 19th, 2008
Hi all,
Previously the ASDM on my XP Prof PC is working fine ..
But some how this 2 days. The ASDM got error and the message is as below:-
"ASDM cannot be loaded. CLick ok to exit ASDM. Unconnected sockets not implemented"
Any advise ?
owillins Wed, 11/26/2008 - 11:51
Make sure you have installed correct version of java. The ASDM launcher on any host supports Java 1.4.2 and Java 1.5.0.It looks like we have Java 1.6.0 update 10 or update 7.You could check the current Java version on the host through the control panel in WINDOWS. Kindly download Java 1.5.0 and install it on the host where you get this error. You do not have to uninstall current Java to install Java 1.5.0.When you run the new Java file, new updates would be overwritten.
jason_nah Wed, 11/26/2008 - 16:57
I remove the Java 6 update 10 and revert back to Java 6 Update 5 and problem resolved.
Thanks.
