Adding tunnel to existing transport VPN configuration
Nov 19th, 2008
I've been checking steps on adding a vpn tunnel to an existing configuration and found this example on the wiki explaining IPSec between networks.
Do we follow similar steps when the case is host to host rather than network? Are there other steps related to step 3 and NAT? It isn't clear how the two access list entries work together.
My main concern is disrupting remote access during the testing, especially if this requires multiple changes.
existing pix 515 config file output:
sysopt connection permit-ipsec
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set myset
crypto map mapname 10 ipsec-isakmp dynamic dynmap
crypto map mapname interface outside
isakmp enable outside
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
To add a new tunnel between my host and the remote host:
Peer ip address:- 68.180.206.184
Local host :- 209.85.171.99
Remote host :- 68.180.210.120
1. Remove the crypto map that exists off the outside interface.
no crypto map mapname interface outside
2. Create new crypto access-list with the source as the internal network of the PIX Firewall and the destinations as the remote network.
access-list 103 permit ip host 68.180.210.120 host 209.85.171.99
3. Create an identical access-list for Network Address Translation (NAT) 0 as crypto access-list for the NAT bypass.
access-list 102 permit ip host 68.180.210.120 host 209.85.171.99
4. Create a new crypto map with the same name, but with a different sequence number.
crypto map mapname 20 ipsec-isakmp
crypto map mapname 20 match address 103
crypto map mapname 20 set peer 68.180.206.184
crypto map mapname 20 set transform-set myset
5. Configure the ISAKMP policy preshare key.
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash sha
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
isakmp key address 68.180.206.184 netmask 255.255.255.255
6. Bind the crypto map to the outside interface.
Ping the remote host to bring up the new tunnel.
