CRS Editor scripting - need to limit characters to 5
Answered Question
Nov 19th, 2008
I have a script
where i use GetDigitString.
in the fourth pane i can define the length of the DigitString. [Input Length:]
I need it to be exactly 5 characters long
composed by 4 digits and a trailing #
What is the best way to do this.
Correct Answer by david.macias about 8 years 2 months ago
I've not used CRS in a long time, but wont your formula allow 123# to go through?
david
Overall Rating: 3 (1 ratings)
Borkes1985 Thu, 11/20/2008 - 00:25
I assume you probably have 4 and 5 digits dialpans, maybe you should use timeout option of GetDigitString, when only 4 digit are sent.
For example the SendDigits object in the case of timeout..
flyingduckdk Thu, 11/20/2008 - 00:34
I was kinda of hoping i could solve this by
(im new at this) Changing the value of InputLength to something like InputLength = 5 chracters
flyingduckdk Thu, 11/20/2008 - 05:15
Solved it by
adding a new IF sentence under the Succesfull criteria, containing a string variable, with the condition like this:
strNewClose.length() ==4
if true, then continue, if false play error message and go back to step before :)
i got help from my local cisco expert.
Correct Answer
david.macias Thu, 11/20/2008 - 08:25
david
flyingduckdk Thu, 11/20/2008 - 10:42
allmost ... i want it to allow 1234 and to end it by # :) bu i got it working :) lik i said above
