Problem in Spanning-Tree
Nov 20th, 2008
I am facing a problem in spanning-tree implementation and need to know the Cisco gurus opnion. The scnario is explained below
Device-1 7609
Device-2 2960 and 3750
Device-3 Non cisco switches
Now D1 has Multiple spanning-tree defined witth following counters parameter
spanning-tree mst hello-time 1
spanning-tree mst forward-time 4
spanning-tree mst max-age 10
spanning-tree mst 0-1 priority 24576
While D2 and 3 has the same values for these parameters.
Two instances are defined in addition to instance 0
instance-1 includes vlan used in D3
instance-2 includes vlan in D2
All switches in D2 and D3 are connected to D1 i.e. 7609.
All vlans in D2 are defined in instance 1 of D1
All vlans in D3 are defined in instance 2 of D1
D1 is the root for MST topology.
The problem is that everytime we define a vlan in D1-instance-2. the whole segment get disturbed, high CPU and eventually a major outage occurs.
My question is
Should I put all vlans in one instance.
In a region, all devices should have all the vlans in similar instance? e.g. if D2 has vlans in instance-1 should I define the same D3 or vice versa?
Let me know if more information is required
Giuseppe Larosa Thu, 11/20/2008 - 02:48
  • Hall of Fame,
    Founding Member
Hello Kashan,
my understanding of MST is that all devices need to agree on:
region name
region revision number
the Vlan mappings have to be consistent on all devices.
So :
Have you defined on D2 devices that the range of vlans in D3 are in instance 2 ?
and the opposite on devices in D3 ?
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/spantree.html
another note:
actually only BPDUs of instance 0 are sent out ports so at least one vlan has to stay wih instance 0. But on this point I'm not sure there have been other threads about MST with different opinions on this.
Hope to help
Giuseppe
