apply CMC and FAC to ccm 4.0
Nov 20th, 2008
Hi expert,
We have installed Cisco call manager version 4.0 and it has been
configured for two groups to facilitate local calls and IDD calls both. So now we
have a problem of applying a security code for IDD calls to prevent unnecessary
IDD calls being used by unauthorized persons. If there is no option on
this version please advice us the recommended version or at least is there any
option on 7905 series phone to do.
Client Matter Codes and Forced Authorization Codes
Can not I used the above two options with ccm version 4 as cisco unified
communication manager and if it is posible please let me know how do I
configure it.
sampath
Overall Rating: 3 (1 ratings)
mihirasampath Thu, 11/20/2008 - 21:42
thank you for helping me.
actualy what i want is to prevent misuse the phone by unathorized persons.so can i update my ccm v4.0 to v4.1 without changing any configuration or can i restore my v4.0 backup file direcly to the ccm v4.1
thanks
sampath
Jaime Valencia Thu, 11/20/2008 - 22:27
you can upgrade from 4.0(2a) to 4.1(3) to have the FAC and CMC features. you may also think of going to 4.2(3) for that matter. simply check the HW compatibility to make sure your server supports the version.
usually all you need to upgrade is the OS beforehand
BARS backup and restore needs to be done on the EXACT SAME VERSION, meaning EXACT SAME SR or ES. so no, you cannot backup 4.0 and restore on 4.1
java
if this helps, please rate
mihirasampath Thu, 11/20/2008 - 22:58
thank you
your ideas will help me to do my job.
thanks again for your quick respond.
sampath.
