godzilla0 Mon, 11/24/2008 - 09:27
Ok so as I understand this doc, we only have to no-shutdown our free LAN ifaces on the routers, link the routers with a brand new cable, set the interfaces to a new subnet, create a crypto map to apply it to the new interfaces and then apply this block of code to each interface ( don't mind the example subnet example )
interface FastEthernet0/0
ip address 172.16.172.52 255.255.255.240
duplex full
speed 100
standby 1 ip 172.16.172.53
standby 1 priority 200
standby 1 preempt
standby 1 name VPNHA
standby 1 track FastEthernet0/1 150
crypto map vpn redundancy VPNHA
ip address 172.16.172.54 255.255.255.240
ip directed-broadcast
duplex full
standby 1 preempt
standby 1 track FastEthernet1/0
Thanks.
Istvan_Rabai Mon, 11/24/2008 - 09:59
  • Gold, 750 points or more
Yes, and you should create the VPN tunnel between the HSRP virtual IP address (172.16.172.53) and the remote inteface.
I.e. on the remote router you should apply the "set peer 172.16.172.53" command within the static crypto map.
On the HSRP routers you will need to create dynamic crypto maps, possibly with reverse route injection.
Cheers:
Istvan
cisco24x7 Mon, 11/24/2008 - 11:08
  • Silver, 250 points or more
Keep in mind that the configuration does NOT
offer IPSec STATEFUL failover.
Istvan_Rabai Mon, 11/24/2008 - 13:09
Yes,
Stateful failover is a different story. Only some high-end platforms have that feature.
Istvan
cisco24x7 Mon, 11/24/2008 - 16:29
platform such as 2851 and 3845 can support
IPSec stateful failover.
That being said, IPSec stateful failover does
not work well on Cisco as compared to other
vendors such as Checkpoint or Juniper.
godzilla0 Tue, 11/25/2008 - 00:21
Ok, I'm only interested on physical redundancy anyways. Thank you all-
