MOH for incoming calls
Nov 20th, 2008
We are currently running CCM 5.1 on a network with about 40 cisco IP phones. MOH works perfectly for transfers within the network. However, for incoming calls, all you hear are 3 beeps that keep re-occuring. How do we activate MOH for external calls on hold?
rob.huffman Thu, 11/20/2008 - 05:32
Hi Rachel,
It's hard to say without knowing a few more details, but I would check that you have assigned a MRGL to the Gateways;
Here are some docs that may help :)
If you go through the step by step for CCM 5.1(x) MOH, you will probably find the issue;
Media Resources Interactive Voice Network Configuration Example
CallManager Music on Hold Frequently Asked Questions
Let us know,
