RTMT on MAC OSX
Anyone know if it's possible to run RTMT Linux on a Mac, OSX version 5.5?
TIA,
Brian
15 Replies 15
htarra
Level 4
Level 4
Try the bug id CSCsa98374. Installer:Can't launch RTMT on linux....
I can not find this bug CSCsa98374, error found on bug's tool,
Thanks.
If this helps, do not forget, rate!!
Yes you can, I am running Lion and this followed this page and works fine
http://www.ciscomonkey.net/rtmt-on-mac/
CCIE-Collaboration #24527
Alfredo Naranjo
I have the same problem with MAC OSX Sierra 10.12, is there a version to run on my OSX?
Thanks in advanced
Alfredo.
It works fine on Macos 10.12
Just download linux version and run
sh CcmServRtmtPlugin.bin  LAX_VM /usr/bin/java
in terminal
some plugins may need a litle touch here and there.
Hi Hafwhor,
I will try it, thank you so much.
By the way, I couldn't find that URL.
Look at this: http://www.ciscomonkey.net/etc/2016/01/26/new-site.html
Alfredo.
See posts below for url
salhadef
@Hafthor Hilmarsson O'Connor Woud you mind sharing how you compile RTMT to run as a macOS app? It would be very helpful.
I did not compile it myself, so don't know , got it through side channels.
However you can just do "show packet content" and upgrade the relivant files.
Just made version for the 14.X if someone wants it. Just looked at the source from my old file and replaced the relivant files for version 14 linux version and it runs smooth.
RTMT Monitor Tool version 14 CUCM
here is the url.
https://haffi.is/rtmtmac14.zip
I'm running monterey and it says its damaged and should be moved to trash
Hafthor... any chance you have that for CCX 11.6.x?   TIA -Brian
