11-20-2008 05:29 AM - edited 03-04-2019 12:25 AM
below is my ospf setting,
router ospf 100
network 192.168.1.0 0.0.0.255 area 0
network 172.16.1.5 0.0.0.3 area 1
what is different if I change to
"network 172.16.1.4 0.0.0.3 area 1"
which one is better?
or
rdgs
Solved! Go to Solution.
11-20-2008 05:33 AM
Anita
Generally it would be either
network 172.16.1.5 0.0.0.0 area 1
OR
The mask just allows you to be very specific about which interfaces to run OSPF on.
As to which is better, well in this case it doesn't make a lot of difference because 172.16.1.4 0.0.0.3 only covers 172.16.1.4 -> 172.16.1.7.
Jon
11-21-2008 06:23 PM
Anita
It should be the same result.
I believe that you can type it in as:
but when you do show run I believe that you will find that IOS has translated and it will show up as:
This is because the address you want to input and the mask are inconsistent. The mask of 0.0.0.3 indicates a subnet address with mask of 255.255.255.252 and IOS will translate what you input to show the subnet address if you use the "subnet" nask.
Rick
11-20-2008 05:33 AM
Anita
OR
Jon
11-21-2008 05:49 PM
can I config as
Is it the same result?
rdgs
11-21-2008 06:23 PM
Anita
Rick
