Call Manager providing caller information
Nov 20th, 2008
For outbound calls, I would like to send out the calling number (DID number) to the carrier so that they can track all outbound calls that originate from the Call Manager. I have found a Clusterwide Parameter setting "Calling Party Number Screening Indicator" which provides an option for the Call Manager to provide the calling number. Would that be the right option to select and is there anything else that needs to be changed to have that information sent to the carrier?
Thank you.
Jaime Valencia Thu, 11/20/2008 - 07:56
you can simply configure whatever number you want to send to telco under the GW config. all calls routed thru the GW will go out with that ANI
java
if this helps, please rate
roseeng69 Thu, 11/20/2008 - 08:15
What if I want to have each callers' DID number appear for outbound call? Isn't that set up in the Call Manager not the GW? Thanks again!
Jaime Valencia Thu, 11/20/2008 - 08:22
yes, configure it either in the route pattern or route group.
i never mentioned configuring the actual GW, i mentioned the GW config IN CUCM
java
