IPTV with cisco infrastructure
Nov 20th, 2008
Hi all,
I connected the iptv feed to the vlan 17 in edge 3560 switch with all the clients connected to that same vlan 17.It is fine.
If i connect the IPTV feed to the core 4503 switch and connecting the clients to the edge switches, then there is no feed accessible by the clients.
Edge and core trunked with Dot1q.
How can we solve this issue.
All the switches configured with global cmd ip igmp snooping.
Thanks in advance
swami
scottmac Fri, 11/21/2008 - 06:27
  • Green, 3000 points or more
Do you have broadcast suppression turned on? (Turn it off)
What is your MTU size from end-to-end? (open it up to permit a 1500 Byte frame inside the trunk / tunnel)
