Global NAT
Answered Question
Nov 20th, 2008
folks
i need to nat ALL outbound traffic for ALL applications to a single IP on my ASAs external interface but i'm not sure which type of nat to use
previously we used a global nat but i suspect i need a static nat rule for the internal interface and use the external interface for outbound translation
am i on the correct track?
thanks to anyone taking the time to reply
Correct Answer by Jon Marshall about 8 years 5 months ago
Michael
You only need a static if the connection is initiated from the outside to the inside.
If your requirement is simply to NAT all outbound traffic and all outbound traffic is initiated from inside ie. none of the traffic is return traffic from a connection initiated from the outside then
nat (inside) 1 0.0.0.0 0.0.0.0
global (outside) 1 interface
will do the trick.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Thu, 11/20/2008 - 06:21
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Michael
will do the trick.
Jon
