URL syntax for a CSS
Nov 20th, 2008
We have a 11503 acting as a reverse proxy and I am having some issues matching a url. The url we want to match is "/bc/gui/sap/its/zhrits_". I have tried various combinations but cannot get a url ending in _ to work. Is _ a valid ending character on the CSS? All my other urls work except for the 2 which end in _.
content zhrits
balance url
vip address x.x.x.x
add service hr3hrt00
protocol tcp
port 80
url "/bc/gui/sap/its/zhrits_/*"
Gilles Dufour Fri, 11/21/2008 - 05:33
I have tested your config and it works.
check with 'show summary' if you have hits under the appropriate content.
jbest1028 Fri, 11/21/2008 - 05:37
zhrits Active hr3hrt00 0
When I tested the site, I didn't get hits on any rule. I have hits on all the rules except for the 2 that end in _.
Gilles Dufour Fri, 11/21/2008 - 06:22
I'm using an 8.x version.
Which one do you use ?
Did you try to create rule with a unique vip address and your url.
Just to make sure there is not another rule catching your traffic.
jbest1028 Fri, 11/21/2008 - 06:54
I am using 8.20.
Here is what is happening with this testing. What I did was suspend all rules accept for this rule. When I tried to connect, I got connection failed in browser even though the rule showed active. Now if I turn on another rule(this could be any rule), I get the error message "Connection Interrupted". So it looks like the rule isn't even listening for the incoming request. When I have another rule active, it tries to match to that which causes the "Connection Interrupted". I also do not have the catch all rule (/*) in place yet since I wanted to test the url matching first.
jbest1028 Fri, 11/21/2008 - 07:13
One more thing, I also don't see a flow created why I try to hit this rule.
Gilles Dufour Fri, 11/21/2008 - 08:03
this is weird.
It could be broken.
You should open a service request with the TAC so that we can investigate further.
