CUPC on phone status
Nov 20th, 2008
CUCM 6.x, cups 7.x and cupc 7.x.
When we mnually change status on a cupc client it updates the status on other clients(within their contacts).However if I pick up the phone I do not see status updates (i.e I woould expect to see busy or on the phone). ACL's are set to all. Tried most of the suggestions re this issue on other posts.Cheers, Jeff
jeff.singh_2 Thu, 11/20/2008 - 13:04
Doug,
thanks for the reply, yes DN is associated with a user.
jeff.singh_2 Tue, 11/25/2008 - 10:28
thanks for the reply, no not using EM - re applied all the config again and this time worked fine ??? can't explain it - config was as originally input but this time it worked.
