Q-in-Q
Nov 20th, 2008
I am interested in having a particular VLAN in two separate sites. I have read a little about it and was wondering if it would be possible to do across a point-to-point DS3 connection. I see a command on my serial link "Router2(config-if)#dot1q tunneling ethertype ?"
Will this command help me do what I want? I just want to be able to have a particular subnet in two different cities where it's not an option to split it.
Jon Marshall Thu, 11/20/2008 - 07:01
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jason
If you want to extend a L2 vlan over a L3 routed link then L2TPv3 will allow you to do this -
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t2/feature/guide/gtl2tpv3.html
You don't say what routers you are using or what IOS you have. L2TPv3 is not supported on all routers.
Jon
snickered Thu, 11/20/2008 - 07:51
Router1:
Model: 7206VXR
IOS: C7200P-ADVENTERPRISEK9-M 12.4(15)T5
Port Adapter: PA-2T3+=
Router2:
Model: 7204VXR
IOS: C7200-ADVENTERPRISEK9-M 12.4(15)T1
Will this do? From what I can see "2-port T3 port adapter" will work (if that's what PA-2T3 is). And it looks like the 7200 series has been supported as of 12.0(21)S.
You wouldn't happen to have a base config for the interfaces, would you?
snickered Thu, 11/20/2008 - 08:18
The way I understand this is that you can't do this across a L3 link. Am I correct on this?
Giuseppe Larosa Thu, 11/20/2008 - 08:36
  • Hall of Fame,
    Founding Member
Hello Jason,
you are correct 802.1Q tunneling is a MAN feature provided by a L2 Service Provider, in your case L2TPv3 is the right tool as explained by Jon.
Hope to help
Giuseppe
