voice dsp's and codecs
Nov 20th, 2008
Hi all, trying to understand a bit more about dsp resources.
I have a 2821 which if you issue the command "sh diag",tells me I have in slot 0 a PVDM2-32 in slot 0 and similarly in slot1.
when I issue the command sh voice dsp group all" I get:
DSP groups on slot 0:
dsp 1:
State: UP, firmware: 4.4.10
Max signal/voice channel: 16/16
Max credits: 240
Group: FLEX_GROUP_VOICE, complexity: FLEX
Shared credits: 30, reserved credits: 0
Signaling channels allocated: 16
Voice channels allocated: 8
Credits used: 210
Voice channels:
Ch01: voice port: 0/0/0:15.3, codec: g711ulaw, credits allocated: 30
Ch02: voice port: 0/0/0:15.7, codec: g729br8, credits allocated: 30
Ch03: voice port: 0/0/0:15.24, codec: g729br8, credits allocated: 30
Ch04: voice port: 0/0/0:15.27, codec: g711ulaw, credits allocated: 15
Ch05: voice port: 0/0/0:15.10, codec: g711ulaw, credits allocated: 30
Ch06: voice port: 0/0/0:15.1, codec: g711ulaw, credits allocated: 30
Ch07: voice port: 0/0/0:15.25, codec: g711ulaw, credits allocated: 15
Ch08: voice port: 0/0/0:15.9, codec: g729br8, credits allocated: 30
dsp 2:
Max credits: 240
Shared credits: 90, reserved credits: 0
Signaling channels allocated: 0
Voice channels allocated: 0
Credits used: 0
Voice channels:
dsp 5:
Max credits: 240
Shared credits: 120, reserved credits: 0
Credits used: 0
Voice channels:
dsp 6:
Max credits: 240
Shared credits: 105, reserved credits: 0
Credits used: 0
Voice channels:
DSP groups on slot 1:
This command is not applicable to slot 1
DSP groups on slot 2:
This command is not applicable to slot 2
Questions:
why dsp 1,2,5,6 what happened to 3,4
I take it the pvdm's in slot 0 and 1 referenced in the sh diags, are just grouped together in the show voice dsp group command?
I thought g729br8 was a high complex codec, but if so why does it get allocated 30 credits, if 240 credits is the max per dsp then thats 8 g729br8's, i thought the max was 6 per 2-16 dsp?
What happens if you use all the credits on your dsp's, but still have spare channels, would a call in be refused?
thanks
