Forcing broadcast or multicast traffic
Nov 20th, 2008
Is there a way to do this? I'm testing storm control on a switch.
Overall Rating: 5 (1 ratings)
Collin Clark Thu, 11/20/2008 - 07:10
For multicast traffic try MCAST or VLC. Broadcast is a little harder, Wireshark should be able to do it.
Hope that helps.
John Blakley Thu, 11/20/2008 - 07:16
How can I use Wireshark to generate a broadcast storm? And do you mean the vlc player? Also, I don't have this switch connected to anything. I have two laptops connected to it and a router that doesn't have a connection to the internet; it's strictly a lab setup. I wanted to generate enough traffic to keep the other laptop from being able to ping the router consistently. If I have to stream actual video for multicast, then that won't work because I can't put my router on the network.
Thanks Collin!
Collin Clark Thu, 11/20/2008 - 07:28
Honestly I've never used Wireshark to generate traffic, but I know it can. Yes I mean the VLC player, you can use it to generate a multicast stream from one of the laptops. I don't think you need the router on the network for multicast, I think you can do it with what you have. I rarely do multicast, so I'm no expert, but with IGMPv3 I think it can be done.
