VideoTelephony between CCME and CCM6 : Is it possible
Nov 20th, 2008
I've posted here some message, but i don't see there.
So I retry to send the post :
Is it possible to make videotelephony between CCME and a CCM6 ?
Actualy, there is two sites. The main Site use a CCM6 and the remot site use a CCME. In each Office already use Videotelephony.
So I want that the two offices can make videotelephony.
Is it possible?
Overall Rating: 3 (1 ratings)
Jaime Valencia Thu, 11/20/2008 - 14:19
yes, if they're going to be from endpoint to endpoint yes, videoconferencing would require an MCU
java
if this helps, please rate
connect101 Thu, 11/20/2008 - 23:56
I just want a Point to point VideoTelephony.
between CCME4.0 and CCM6.
Do you have any link to see how to do this.
