Does a 6500 work as a LNS router?
massipace
I have a 6506 platform and I would like to end L2TP sessions on this device, AAA authentication for dialin user and configure av-pair attributes. Has 6500 platform any way to accomplish the request? Is there any special card that can do this work? I read about a MWAN card but I'm not sure can be a solution for my problem.
Massimiliano
amritpatek
Level 6
Level 6
The Cisco Multiprocessor WAN Application Module (MWAM) is a Cisco IOS software application module that you can install into the Cisco 7600 Series Internet Routers. The MWAM allows you to run multiple instances of Cisco Ethernet Service Aggregation applications, such as L2TP Network Server (LNS) and Service Selection Gateway (SSG) application software.
The MWAM requires the following system configuration:
Cisco IOS Release 12.2(14)ZA3 Supervisor image installed on the Cisco Catalyst 6500 Series Supervisor Engine 2.
For further information click this link.
http://www.cisco.com/univercd/cc/td/doc/product/core/cis7600/relnotes/esa_rn.htm
amritpatek
Level 6
Level 6
