11-20-2008 07:43 AM - edited 03-04-2019 12:25 AM
I have a tunnel set up between two 2611 routers over a DSL connection using Zhone Paradyne modems, the problem is I cannot ping the destination tunnel address, I can ping the DSL internet address proving connectivity between the two. To further complicate matters I can ping a second tunnel address located somewhere else. I have tried using tunnnel mode ipip but this has not solved the problem. All ip routes are set up as required.
This is an extract from the config:
interface Tunnel2
description Residence link
ip address X.X.X.77 255.255.255.252
tunnel source Ethernet0/0
tunnel destination X.X.X.X
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip route X.X.X.128 255.255.255.240 Tunnel2
Does anyone have any ideas please..? Thanks.
11-20-2008 08:48 AM
Hello Gurcharan,
if X.X.X.X tunnel 2 destination is an IP address taken from X.X.X.128 255.255.255.240 your configuration is not correct:
you can route over the tunnel everything expect the tunnel destination itself
else your config is fine
Hope to help
Giuseppe
11-20-2008 09:04 AM
Hi Giuseppe,
thanks for your input, the tun2 destination address is not in the range you say, it's actually an internet IP starting 190.X.X.X as supplied to our DSL line by the ISP.
I should have made this clearer in my original Post.
The thing that puzzles me is that I can ping a tunnel address (there are 2 tunnels set up) back to the UK from this router and vice versa, but not the tunnel address that is between the two routers out in that country, not sure if it has anything to do with MTU size, but would not have thought so as otherwise it wouldn't be able to ping the other tunnel. Also GRE must be enabled on the Paradyne router as again it wouldn't have allowed ping to the one tunnel.
Gurch.
11-20-2008 09:10 AM
Hello Gurch,
mine was just a basic check.
Can you reach the destination prefix behind your tunnel ?
I have remote sites in our network where I cannot ping the tunnel GRE destination but I can reach the internal LAN ip address
Hope to help
Giuseppe
11-20-2008 11:15 AM
Hi Giuseppe,
I can only reach the destination from the UK router, I cannot reach from either router at each end at either remote site, so therefore I cannot reach the internal LAN IP address.
If I could ping the internal LAN IP from each remote site to each other then my problem would be solved I think.
Thanks.
Gurch.
11-20-2008 01:15 PM
Can you post a config?
11-21-2008 02:00 PM
Here you go, config as requested...
Current configuration : 1517 bytes
version 12.2
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Remote_One
logging rate-limit console 10 except errors
ip subnet-zero
no ip finger
no ip dhcp-client network-discovery
interface Tunnel1
description Home
ip address 10.204.18.82 255.255.255.252
tunnel destination 107.128.115.250
interface Tunnel2
description Remote_Two
ip address 10.204.18.77 255.255.255.252
tunnel destination 100.90.58.200
interface Ethernet0/0
ip address 192.168.1.3 255.255.255.0
half-duplex
interface Serial0/0
no ip address
shutdown
interface Ethernet0/1
ip address 10.101.100.120 255.255.255.248
half-duplex
interface Serial0/1
no ip address
shutdown
ip classless
ip route 10.202.0.0 255.255.0.0 10.202.122.121
ip route 10.204.1.0 255.255.255.0 Tunnel1 permanent
ip route 10.204.130.120 255.255.255.240 Tunnel2
ip route 195.70.48.200 255.255.255.255 192.168.1.1
ip route 192.168.12.230 255.255.255.255 Tunnel1
ip route 107.128.115.250 255.255.255.255 192.168.1.1
no ip http server
line con 0
login local
transport input none
line aux 0
line vty 0 4
login local
line vty 5 15
login
no scheduler allocate
