intermitten duplex mismatch on Cisco router 2800
Nov 20th, 2008
At our remote location, every once in a while, the metro connection from there to our building, will come up with a duplex mistmatch error.
Both interfaces are set to full duplex..however the only way to fix it, is if i reboot the router at the other location..then its good for a while, but again, every once in a while comes back with a duplex mismatch.
Any ideas?
John Blakley Thu, 11/20/2008 - 08:03
  • Purple, 4500 points or more
Bad cable maybe. If you have both hard coded, it shouldn't be negotiating at all. I would check the cable.
--John
accesshollywood2 Thu, 11/20/2008 - 08:22
Thanks John!
I asked another senior engineer the same question and he gave me the exact same answer..
I just didnt want to get too technical when i know it is going to be something simple..
I will run new cable becuase the cable at the other building is kinda old anyway...
