Internet script editor not working
Answered Question
Nov 20th, 2008
ICM version 7.0
Iscripteditor is not working for one CICM instance though its fine for other CICM and NAM.
Correct Answer by cvenour about 8 years 8 months ago
Are they all talking to the same AW? If not, check that the CICM's AW has the Internet Script Editor option checked. Also make sure that you are using the correct credentials and have the instance set correctly when attempting to connect.
C.
Overall Rating: 4.5 (2 ratings)
Correct Answer
cvenour Thu, 11/20/2008 - 15:55
C.
sandeep pokhriyal Fri, 11/21/2008 - 05:09
all of them are using same AW.
wherein i can check the option for AW to enable ISE.
geoff@hp.com Fri, 11/21/2008 - 05:38
  • Red, 2250 points or more
Run ICMSetup.exe again from C:\icm\bin.
Geoff
