CCM6 + VTAdvantage : use which video codec?
Nov 20th, 2008
I'm tring to connect a CCM6 with a CCME4 with H323.
In the CCME, I've configured this :
voice service voip
h323
call start slow
interface FastEthernet0/1
description Tamatave
ip address 192.168.130.1 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.130.1
dial-peer voice 201 voip
destination-pattern 8...
video codec h264
session target ipv4:192.168.20.8
session transport udp
dtmf-relay h245-alphanumeric
codec g711ulaw
telephony-service
video
maximum bit-rate 900000
max-ephones 10
max-dn 10
ip source-address 192.168.130.1 port 2000
auto assign 1 to 10
service phone videoCapability 1
system message ConnecTIC IP Everywhere
keepalive 45
max-conferences 4 gain -6
transfer-system full-consult
In the CCM6, i've just configured the H323 gateway.
In the Region, the video bandwidth is 384, and after 1000
REtry Video as Audio is checked.
Result :
Call from the CCME to CCM6:
The VTAdvantage windows is toggled on automaticaly : the local display image, but the remote does'nt.
The voice is Ok.
Question :
1. What is the codec used by CCM6 for video call?
2. How CCM6 Calculate the available bandwith?
I ask this because i'm on a LAN and the bandwitdh is 100Mbps.
So why there is no video?
3. If I call from the CCM6 to the CCME, the is no reaction with the VTAdvantage.
Can I configure the video codec used in the CCM6 ?
Best regards,
