Unsecured wireless network
Answered Question
Nov 20th, 2008
Hi All,
Please how can I secure my wireless network with the following running config:
no aaa new-model
dot11 syslog
dot11 ssid ************
authentication open
guest-mode
interface Dot11Radio0/3/0
no ip address
ssid *********
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
channel 2412
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
Thank you all!
Law
Correct Answer by jeff.kish about 8 years 8 months ago
What kind of security do you want to use? WPA-PSK with AES? If so, perform the following config:
dot11 ssid *******
authentication key-management wpa
wpa-psk ascii [password]
int dot0/3/0
encryption mode ciphers aes-ccm
Try that and see if it works. Hopefully it does!
Overall Rating: 5 (1 ratings)
Correct Answer
jeff.kish Thu, 11/20/2008 - 11:21
  • Silver, 250 points or more
dot11 ssid *******
int dot0/3/0
sr2470182 Fri, 11/21/2008 - 07:14
Thanks Jeff,
It works fine.
Meanwhile I have posted another question about DHCP configuration on WAP
Cheers!
