calls don't establish
Nov 20th, 2008
Hello:
I need help to troubleshooting this:
I have a ipipgw between a sip network and a h323 network. I make a call and the called endpoint (sip) rings and answer the call, but the h245 don't work. The called endpoint is conected but the caller (h323) continous with the alerting message.
What can be the problem? what can I see?
Thanks everbody
Antonio
Overall Rating: 3 (1 ratings)
jbarcena Thu, 11/20/2008 - 09:51
  • Red, 2250 points or more
on the IP2IPGW make sure to have the hairpaning enabled.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
h323
sip
min-se 1000
no call service stop
aherraez77 Thu, 11/20/2008 - 10:09
Hello.
I have the hairpaning enabled.
I have this lines from the degub.
*Nov 20 17:52:23.555: //50/CE6EA6B0801E/H323/cch323_h245_addr_notify: Sending event CC_EV_H245_ADDR, ev 4
*Nov 20 17:52:23.555: //50/CE6EA6B0801E/H323/cch323_h245_addr_notify: Unable to send event CC_EV_H245_ADDR
*Nov 20 17:52:23.555: //50/CE6EA6B0801E/H323/setup_cfm_notify: status = 8000009
*Nov 20 17:52:23.555: //50/CE6EA6B0801E/H323/cch323_h225_set_new_state: Changing from H225_REQ_FS_ALERT state to H225_WAIT_FOR_H245 state
*Nov 20 17:52:32.635: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 3 Event 0x1
*Nov 20 17:52:32.635: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: owner_data=0x641E8358, len=47, msgPtr=0x639D2050
I think that the proble is there but I don't undertand what means.
Thanks you
Antonio
jbarcena Thu, 11/20/2008 - 10:12
Please enable the following debugs:
debug h225 asn1
debug h245 asn1
And upload the result. Seems to be that you can not reach the IP Address that h245 wants to announce (Media)
aherraez77 Thu, 11/20/2008 - 10:28
this is the result (in the attchments). In one moment the h245tunneling is true but later is false. Can be this?
What must I look for here?
Thanks you
Ayodeji Okanlawon Fri, 11/21/2008 - 05:49
  • Cisco Designated VIP,
    2017 IP Telephony
can you post the config on both your h323 gateway and ipipgw
aherraez77 Fri, 11/21/2008 - 05:35
Hello again:
can you see my log? or Where can I see the IP Address that h245 wants to announce (Media)?
The problem is that the h245 channel don't establish it, but I don't know why not?
Thanks you
aherraez77 Fri, 11/21/2008 - 06:04
Hello:
jbarcena has the correct answer: I have this from the show call active voice:
VOIP:
ConnectionId[0x4C7F85C6 0xB70911DD 0x800AABB8 0x682ED17F]
IncomingConnectionId[0x4C7F85C6 0xB70911DD 0x800AABB8 0x682ED17F]
CallID=10
RemoteIPAddress=10.172.16.248
RemoteUDPPort=0
RemoteSignallingIPAddress=10.172.16.248
RemoteSignallingPort=1720
RemoteMediaIPAddress=0.0.0.0
RemoteMediaPort=0
RoundTripDelay=0 ms
SelectedQoS=best-effort
tx_DtmfRelay=inband-voice
FastConnect=FALSE
AnnexE=FALSE
Separate H245 Connection=FALSE
H245 Tunneling=FALSE
the RemoteMediaIPAddress=0.0.0.0, so the h245 don't works. But I don't know why? may be is a problem in my GK. Its from Polycom. It works in routed mode but the rtp traffic is between endpoints.
any idea?
Ayodeji Okanlawon Fri, 11/21/2008 - 06:07
    2017 IP Telephony
Make sure you have this command on the h.323 gateway interface that you are sending calls to from the ipipgw:
h323-gateway voip interface
h323-gateay voip bind srcaddr X.X.X.X
where x.x.x.x = ip adddress of the interface
aherraez77 Fri, 11/21/2008 - 08:25
Hello:
I have configured this commands. The setup goes fine and the h323 endpoint answer the call but the gw don't know their ip address.
Ayodeji Okanlawon Fri, 11/21/2008 - 08:36
    2017 IP Telephony
Has your problem been solved? Do you still have the problem you have? I have had this problem in the past and this is how I resolved it
aherraez77 Fri, 11/21/2008 - 09:15
Hello:
I have writed the wrongs words. The commands were configured from the begining. And I still have the problem. I think that the remote ip address must be the ip from the h323 endpoint. The gw doesn't know it.
DWAM_2 Mon, 11/24/2008 - 05:36
I think I have the same problem.
The architecture is :
IP_Phone - CUCM 6.1.2 last patch - H323 - Cube IP IP GW - SIP - CIRPACK - External Phone
When I do a call from Ip Phone to External Phone, I have got the Ip_Phone Busy. 3 seconds later, the External Phone rings and there is no communication.
I have seen that :
RemoteIPAddress=192.168.44.1
RemoteUDPPort=0
RemoteSignallingIPAddress=192.168.44.1
RemoteSignallingPort=33862
What do you think about that?
Have you got a solution ?
Best regards.
aherraez77 Mon, 11/24/2008 - 11:07
Hello:
I don't have a solution.
I think that the problem is in the h245 tunneling and fast start. I think that my gk don't use h245 tunneling and I must to hold the H.245 connection procedures until after the H.225 connections are made
I don't know at 100%.
How can I turn off the h245 tunneling? I have tested with slow start but, I still have the problem so I want to try with the tunneling.
Thanks everyone
Antonio
thierry.berwart_2 Mon, 12/01/2008 - 06:42
Hi !
Whe have the same issue here...
Did you find a solution ?
Kind regards,
Thierry
DWAM_2 Tue, 01/06/2009 - 07:15
we have done an ip to ip with SIP to SIP connection. We haven't found a solution with H.323
Best regards.
