Cisco 857 Firewall error
Nov 20th, 2008
I have a new Cisco 857 router and cannot get the firewall configured. When I try to delivery the firewall config to the router (I'm using SDM delivered with the router) I get an error as follows
class-map type inspect imap match-any sdm-app-imap
Error detected at this command. Click OK
I have recently configured two 877 routers using SDM with no problem. Is there an issue with the 857??
armadasols Fri, 11/21/2008 - 01:23
I think it is set to match invalid-command. But I am configuring the firewall entirely using SDM so it is creating these classes. I assume it is using whatever the default settings are. I have also done some digging and I believe there is a known bug in SDM that tries to implement features on some routers that they do not support. Is this correct and could this be the nub of the problem here?
