John Blakley Thu, 11/20/2008 - 13:39
  • Purple, 4500 points or more
I figured it out, so I'm going to let everyone know for those that don't.
If you have a user who has priv level 3, then the commands that you want to hide need to be configured for a higher priv level.
Running a '?' at the # prompt came up with a slew of commands to run, but wouldn't because they weren't granted access. I wanted to hide these, and in order to do so I did:
Router(config)# priv exec level 5 telnet
That hides the telnet command for priv level 3.
HTH,
John
srue Mon, 11/24/2008 - 12:43
  • Blue, 1500 points or more
depending on what yo'ure trying to accomplish, sometimes its easier to go the other direction...
assign someone a lower privelege, then lower the privelege of the commands you want them to have.
