WLC > WLAN > SSID > L3 Security > Passthru
Nov 20th, 2008
  • Bronze, 100 points or more
With passthru security the end user get a pop-up warning about accepting the self signed certifcate from the virtual ip 1.1.1.3.
Is there a way to replace the certificate with a trusted public certificate?
c.fuller Mon, 12/08/2008 - 09:03
You can disable https: on the controller. This will eliminate that windows pop-up warning. You need to reboot the controller for change to take effect.
Or you can install an actual SSL certificate on the controller.
For ease of administration I went with option 1 so I did not have to worry about renewing the certificate every year.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
