11-20-2008 03:06 PM - edited 03-06-2019 02:36 AM
Is it true that you can't build a layer 3 etherchannel using PAgp?
11-20-2008 03:42 PM
No that is NOT true.
int 1/1
channel-group 1 mode desirable
int 2/2
int po1
no switchport
ip address x.x.x.x y.y.y.y
is a layer 3 etherchannel and works perfectly.
Only limitation that i know of in Pagp is that you can't build cross-stack etherchannels with Pagp. You can with Lacp and mode on.
11-20-2008 03:48 PM
thank you. One of the engineer at my work was putting doubts in my mind.
11-20-2008 04:42 PM
I believe it is also true that you can only use PagP interconnecting Cisco devices? If using other branded hardware in your network you should use LACP. This is what we have in our environment.
11-21-2008 03:47 AM
Yes, Pagp is Cisco propriatery. LACP is non-prop standard.
