the ring for second call
Nov 20th, 2008
Hi Gurus,
I am wondering if the following feature is available.
The busy trigger for each line is setup as two calls. So when one call is active, a second call can still ring/display on the active phone.
Question:
Is it possible that a caller receives a different ring tone when he calls in but a call is already active on the same line? Thanks.
Jaime Valencia Thu, 11/20/2008 - 17:50
unfortunately that is not available, all calls will hear the same tone independently if the line is idle or already with a call but being able to receive more calls
java
if this helps, please rate
