no data for debug isdn q931 and 921
Answered Question
Nov 20th, 2008
  • Green, 3000 points or more
I can not for life of me figure out why these two debugs will not show the actual calls coming in/out of the router. I have term mon on, I see events, but no call traffic
Correct Answer by aherraez77 about 8 years 5 months ago
Hello.
It is not a rumor. If you use telnet, you must to use the terminal monitor command to see the debug. This must be done for all debugs from telnet
Overall Rating: 5 (1 ratings)
jbarcena Thu, 11/20/2008 - 16:10
  • Red, 2250 points or more
Are you sure is an isdn?
If its a T1 CAS you might want to try 'debug vpm signal' 'debug voice ccapi inout'
What is your topology?
Tommer Catlin Thu, 11/20/2008 - 16:14
nope just 2 pris in a 2811 with MGCP. I typically just run these debugs to make sure the call is actually hitting the VG outbound and inbound and I can also see what digits are being sent from the carrier. Im getting nothing!@ it's really odd
Tommer Catlin Thu, 11/20/2008 - 16:31
i heard a rumor you cant use console, you have to use telnet to view q931 debugs. bah!
Correct Answer
aherraez77 Thu, 11/20/2008 - 23:40
Hello.
ghtracey Tue, 12/02/2008 - 22:46
You can see the output from any of the logging methods, IF you set that method to level 7 (debug)
Try:
"logging console 7"
"logging terminal 7"
or
"logging trap 7"
depending on whether you want to see debug output on the console, telnet, or syslog.
I believe the default for console is 5(notification). Just "show logging" to see the various levels.
