Flow control
Nov 20th, 2008
Hi all,
Can someone please tell me how I turn off flow control on a gigabitethernet interface in a 2851 series router. Software is Version 12.4(3d).
The output of show int gi0/0 shows that output flow-control. See below output:
Thanks for any help!
GigabitEthernet0/0 is up, line protocol is up
Hardware is MV96340 Ethernet, address is 0013.7ff7.1f40 (bia 0013.7ff7.1f40)
Description: XXXXXXXX
Internet address is XX.XX.XX.XX/30
MTU 1500 bytes, BW 4096000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Full-duplex, 10Mb/s, media type is T
output flow-control is XON, input flow-control is XON
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 01:31:22
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1061000 bits/sec, 366 packets/sec
5 minute output rate 780000 bits/sec, 373 packets/sec
1629886 packets input, 859123089 bytes, 0 no buffer
Received 0 broadcasts, 10 runts, 0 giants, 0 throttles
11 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
1613090 packets output, 492951756 bytes, 0 underruns
0 lost carrier, 0 no carrier, 0 pause output
Overall Rating: 5 (1 ratings)
tcordier Sun, 11/23/2008 - 03:43
in interface configuration mode should turn flow control off. I am wondering as it should be disabled by default, can you check the interface configuration?
HTH, Thomas
bmcginn Sun, 11/23/2008 - 14:54
Hi Thomas,
I appreciate the response, however I don't get an option of flowcontrol on the interface :(
here is the output..
2851-rtr(config)#int gi0/0
2851-rtr(config-if)#no flowcontrol
% Invalid input detected at '^' marker.
Any other suggestions? Thanks for your help, this problem is proving difficult to overcome.
Brad
Giuseppe Larosa Mon, 11/24/2008 - 08:14
Hello Brad,
I've verified I have a similar condition on GE ports of C7200VXRs with NPE-G2 and 12.4(20)T but I don't see any issue in my network.
Also from the sh interface you provided flow control is based on IEEE pause frames but your pause frames counters are 0 input and output.
It looks like flowcontrol never took place
What problem do you think is related to flowcontrol in your scenario ?
Hope to help
Giuseppe
