To allow connections between specific types of end points in a Cisco Multiservice IP-to-IP Gateway, use theallow-connections command in voice service configuration mode. To refuse specific types of connections, use the no form of this command.
allow-connections from-type to to-type
no allow-connections from-type to to-type
To enable individual dial peers to send H.225 messages with caller-ID updates, use the supplementary-service h225-notify cid-update command in dial peer configuration mode. To disable the sending of H.225 messages with caller-ID updates, use the no form of this command.
and To specify that calls are using QSIG and require supplementary services for call forwarding, use thesupplementary-service qsig call-forward command in voice-service or dial peer configuration mode. To return to the default, use the no form of this command.
no supplementary-service qsig call-forward
For the further description following URl may help you
http://www.cisco.com/en/US/docs/ios/12_3t/voice/command/reference/vrht_s12_ps5207_TSD_Products_Command_Reference_Chapter.html#wp1153942
