phone stuck on 'Unprovisioned'
Nov 21st, 2008
Cisco 7940 ip phone.
I tried to convert the above phone to SIP and now the display says 'Unprovisioned Phone'. I do have SIP in the top right hand corner of the display so it was partially successful.
I read in a cisco doc that this was 'due to the lack of the correct syntax in the
OS79XX.TXT file'. But I've checked the OS79XX.TXT file and the syntax is correct. Other than that I can't find any further info to resolve this. Thanks for any help.
s-adhikary Mon, 11/24/2008 - 03:14
Dear Tony
Can you do one thing , just go to directory number and delete existing unregisterd numbers . then try to add the phone again .
i don't know what is the version you r using
Subhasis
tonyspcrepairs Mon, 11/24/2008 - 05:14
thanks for your response. I managed to solve the problem by using a good SIP.cnf template and then tailoring it to my own settings.
