gatway numbering help
Here is the scenario ive got duel 2851 voice gateways with srst connected to callmanger 5.X . I need to expand the pstn numbering lines to get CLI working and give each site a set of numbers Then they can call the sites from head office using one set of numbers, and they can see who is calling them from the branch sites on the office handsets at the moment all the calls go through one DDI number.
question I have for you is will the dram need expanding in the 2851s - to handle this - and is there anything else I need to to upgrade in the 2851 ( apart form re configuration )- what will i need to change - will i have to Map Outbound VoIP Calls to Specific Digital Voice Ports and recongigure the call manger dial plan
