1231ag troubleshooting for the first time
Nov 21st, 2008
We have 3 1231ag WAPs that are having problems with 1 SSID. Seems the signal is low.
This in not on a WLC, so I guess it's CLI for me.... :(
Can someone point me how to troubleshoot this? I am a newbie at troubleshooting wireless. How do I show how many connections? How can I see settings? What settings should I look for? Etc...
Thanks in advance,
Scott.....
wesleyterry Fri, 11/21/2008 - 21:03
  • Bronze, 100 points or more
I think this command may get you started:
show dot11 statistics client-traffic
I think this will show you all the connections to the radio as well as signal quality. I'd compare the value between the different APs that you have.
However, if 1 SSID on the radio is worse than another SSID on the same radio, then I'd be cucrious to see if there is proof of this. I don't think you can have any kind of interference on one SSID and not the other...
svillardi Mon, 11/24/2008 - 06:29
My laptop sat on that SSID for over an hour last week, so I think the issue was CLIENT based. thanks
Vinay Saini Sun, 11/23/2008 - 06:19
  • Cisco Employee,
Hii ,
As this is not the LWAPP AP , there are different setof commands to check out the client associations. You can find them on cisco.com
You can try ,
Show dot11 associations all - will show all client associated
Show controllers dor11 radio <1/o> - will show you radio settings
Show running config ssid -- will show config of ssid
show running config - will show u all the config on the AP
hope this helps
Vinay
svillardi Mon, 11/24/2008 - 06:24
Thank you very much. Do you have a link where I could find some documentation on it?
