11-21-2008 08:02 AM
Hi all,
Serial link goes down, but backup interface dont come up.
When i saw "show frame-relay pvc", the pvc was not changed state, nevertheless the "show ip int brief" shows me a down down for Serial1/0.1 ...
The router is a Cisco 1760 with a c1700-ipbase-mz.123-13a.bin ios.
I have other routers in other sites wich works perfectly...
Any ideas ?
Best Regards,
Petrónio
interface Serial1/0.1 multipoint
bandwidth 512
ip address 192.168.155.58 255.255.255.252
backup delay 1 1
backup interface Dialer1
frame-relay map ip 192.168.155.57 16 broadcast
interface Dialer1
ip address 192.168.154.58 255.255.255.252
encapsulation ppp
no ip split-horizon
dialer in-band
dialer map ip 192.168.154.57 name colectora_backup broadcast 2xxxxxxxx
dialer hold-queue 10
dialer-group 1
no cdp enable
ppp authentication chap
11-28-2008 02:14 PM
Setup your router interface cards such that the interface w/"physical-layer async" comes before the interface it will be used to back up. It will then get initialized before the "backup interface" command.
Implementing dial-on-demand routing (DDR) backup on a router that uses
Network Address Translation (NAT) involves more configuration than is
neccessary for regular DDR backup. This is because the router must translate packets to and from the "inside" network using different "outside" addresses depending on whether the primary or backup link is active." ... "Make sure that your Internet Service Provider (ISP) can provide you with two different IP addresses or subnets. Use one IP address or subnet for the DSL connection and the other for the backup ISDN connection. IP addresses on the two dialer interfaces need to be explicitly assigned and cannot be negotiated during PPP negotiation. This means that the ip address negotiated command is not permitted under the dialer interfaces.
For troubleshooting the 1706 router click this link.
http://www.cisco.com/en/US/products/hw/routers/ps221/prod_tech_notes_list.html
