CUCM 7 on IBM x346
Answered Question
Nov 21st, 2008
  • Silver, 250 points or more
I have been looking for some data sheets on Cisco.com in regards to upgrading a existing CCM 4.2(3) to CUCM 7. Specifically I'm looking to find out if the IBM x346 series server will support CUCM 7.
Anyone know?
I have found this link but it doesn't state if it supports version 7.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/product_solution_overview0900aecd80091615.html
Justin
Correct Answer by Rob Huffman about 8 years 6 months ago
Hi Justin,
Have a look at Table 3 in this good doc :)
Cisco Unified Communications Manager Server Support Matrix
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Fri, 11/21/2008 - 08:48
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Justin,
Hope this helps!
Rob
Justin Brenton Fri, 11/21/2008 - 08:53
RRR I was so close and missed that doc..... Thanks Rob... ;) This is exactly what I was looking for...
Rob Huffman Fri, 11/21/2008 - 10:48
  • Hall of Fame,
    Founding Member
Hi Justin,
You are most welcome! In the 80 Zillion docs here it's hard to find the one you want sometimes.
Cheers!
Rob
Justin Brenton Mon, 11/24/2008 - 15:59
Hi Rob,
The IBM xSeries 346 that I'm trying to see if supports CUCM 7 is not listed as the server contains a 2.8 ghz intel xeon processor
My server specs:
IBM x346
Intel Xeon 2.8 ghz processor
2 x 70gb HD
2Gb RAM
Any idea's?
Rob Huffman Tue, 11/25/2008 - 06:24
  • Hall of Fame,
    Founding Member
Hi Justin,
You do seem to meet the minimum spec's for a CCM 7.0(1) build;
Cisco Unified CM requires a minimum of 2 GB of memory, 72 GB disk drive, and 2 GHz processor.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/7_0_1/cucm-rel_notes-701.html#wp579941
But, I would be hesitant to proceed without verification from TAC that this will be a supported install. You might also want to engage your Cisco SE to do some research here as well.
Hope this helps!
Rob
