AXl Add Phone but no description is added...
Nov 21st, 2008
Im adding a phone with a SOAP AXL request.
My request contains the <description>Test</description> however nothing shows up in the description field...
Everything else seems to populate...
This is on a CCm 6.1 box...
stephan.steiner Tue, 11/25/2008 - 01:55
  • Silver, 250 points or more
Can you look at the axl traces (set level to debug in the serviceability page first) and check if the description makes it to the ccm?
Also, are you using autogenerated stubs from the wsdl or did you write your own code?
Jeff Garner Tue, 11/25/2008 - 09:28
yes from the trace its getting the descripton...
If I set a description on the line that shows up just not on the phone...
This is my own code...
Here is my soap Envelope from the trace...
http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2000/10/XMLSchema-instance" xmlns:xsd="http://www.w3.org/1999/XMLSchema">http://www.cisco.com/AXL/1.0" xsi:schemaLocation="http://www.cisco.com/AXL/1.0 http://ccmserver/schema/axlsoap.xsd" sequence="1"> BAT00aa3b3c2d67
Test
Cisco 7960Cisco 7960PhoneSCCPUserSS-TESTLABTL-UnRestrictedDP-TESTLABTLTESTLABTLJohn Smith7145551212RouteTESTLABTL-OnNetfalseSS-TESTLABTL-RestrictedOnNettrueSS-TESTLABTL-RestrictedOnNettrueSS-TESTLABTL-RestrictedOnNetDefaultUse System Default42
stephan.steiner Tue, 11/25/2008 - 09:54
Your XML is incorrect... should include the tag as well.
Can you try again with an XML that corresponds to the schema?
Also, AXL debug tracer or dbl debug traces might show that the request is only have processed.. for some reason you seem to get an OK back though (or you didn't mention that you get any errors).
Jeff Garner Tue, 11/25/2008 - 09:58
In my code I do have the lines tag and the line is added to the phone.. I think the trace seperates the adding of the line and the adding of the phone... I get no error back...
Sascha Monteiro Tue, 11/25/2008 - 18:53
I think Stephan means that should be at the end, after
can you show the xml that you are sending?
Jeff Garner Mon, 12/01/2008 - 10:00
Here is the soap XML I am sending:
http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
http://www.cisco.com/AXL/1.0" xsi:schemaLocation="http://www.cisco.com/AXL/1.0 http://x.x.x.x/schema/axlsoap.xsd" sequence="1">
SEP001234567890
Test
Cisco 7961
Cisco 7961
Phone
SCCP
User
SS-test-UnRestricted
DP-test
test
7500
John Smith
7500
Route
test-OnNet
false
SS-test-RestrictedOnNet
true
true
Default
Use System Default
What is interesting is that if I send an updatePhone request and it will update the description.
SEP001234567890
Test
Sascha Monteiro Mon, 12/01/2008 - 10:08
Jeff,
You have 2 elements, before and after you only need it at the latter.
how do you generate the xml?
Jeff Garner Mon, 12/01/2008 - 10:16
Thanks for catching that as well... Even removing the duplicate /newPhone It still does not add the description...
I am generating the XML with Javascript, Im sending this to the CCm via ActiveXObject("msxml2.xmlhttp.6.0");
I may try and redo this all in ASP...
