Using Vista 64 Bit MS VPN Client to VPN to Cisco ASA
Nov 21st, 2008
Hello all,
I am unable to establish a vpn connection using a vista 64 bit ms vpn client. The Microsoft vpn client connects to the ASA with no problem on the xp pro machine. Is any one done this configuration before? Below is my vpn configuration. Your help will be greatly appreciated.
group-policy DefaultRAGroup attributes
dns-server value
vpn-tunnel-protocol IPSec l2tp-ipsec
default-domain value
crypto isakmp policy 15
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
tunnel-group DefaultRAGroup general-attributes
address-pool ISS_Network_Pool1
authentication-server-group ACS
default-group-policy DefaultRAGroup
tunnel-group DefaultRAGroup ipsec-attributes
pre-shared-key xxxxx
tunnel-group DefaultRAGroup ppp-attributes
no authentication chap
authentication ms-chap-v2
crypto ipsec transform-set TRANS_ESP_3DES_MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set TRANS_ESP_3DES_MD5 mode transport
crypto dynamic-map outside_dyn_map 20 set transform-set TRANS_ESP_3DES_MD5
crypto map outside_map 20 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface wan
mbroberson1 Fri, 11/21/2008 - 12:05
I ran into this senario a while back. What I was told from Cisco is that this is not supported. The ASA MSCHAPv2 on Vista is different from the MSCHAPv's on the ASA. Even if they both say MSCHAPv2, underneath they are actually different. If you do find a workaround I would love to know about it.
