Reset Voicemail Password in CUE from CLI?
Answered Question
Nov 21st, 2008
  • Silver, 250 points or more
Is this possible and how do you do it?
I have lost communication via the GUI and working on getting that restored, but need to reset a password now before I restore this.
Rick
Correct Answer by Brandon Buffin about 8 years 7 months ago
Rick,
Yes, it is. From the CUE CLI, enter:
user username pin 12345
Hope this helps.
Brandon
Overall Rating: 5 (1 ratings)
jbarcena Fri, 11/21/2008 - 11:11
  • Red, 2250 points or more
user pin
This is done directly from the command mode, you do not need to login to CUE.
Correct Answer
Brandon Buffin Fri, 11/21/2008 - 11:12
  • Purple, 4500 points or more
Rick,
Hope this helps.
Brandon
Rick Morris Fri, 11/21/2008 - 12:04
This is exactly what I needed.
Thanks!
Rick
