Suddenly I can no longer telnet to asa5510
Answered Question
Nov 21st, 2008
When I try to telnet to the ASA I get a "connection refused by remote host" message. This has been working fine for a year. I've taken out the telnet permission and put it back in, still doensn't work. Has anybody seen this before.
David
Correct Answer by ajagadee about 8 years 7 months ago
David,
If the configuration has not changed and you do have telnet enabled for your address, then check out this Bug ID CSCse08133 against the version you are running.
Also, see if the workaround fixes your problem.
Arul
*Pls rate if it helps*
Overall Rating: 5 (1 ratings)
Correct Answer
ajagadee Fri, 11/21/2008 - 11:09
  • Cisco Employee,
David,
Arul
dvanhaaren Fri, 11/21/2008 - 11:18
Checked the bug, which was basically for ssh and ping. I can ping ok, Tried the readdress. Still same connection refused.
David
dvanhaaren Fri, 11/21/2008 - 11:26
I guess it must have been a timing thing.I just didn't wait long enough It's working now.
Thanks much
David
