Can A Router Emulate A Layer 3 Switch
Nov 21st, 2008
I am building my CCNP lab. Currently I have three 2950 switches and a bunch of routers (3640s and 2610s). I need to practice layer 3 switching, but they seem to start around $200.
Can I use a 3640 with 6 ethernet ports as a layer 3 switch? I know it will switch, but how different will the CLI be?
Edison Ortiz Fri, 11/21/2008 - 11:22
  • Hall of Fame,
    Founding Member
You can create switch virtual interfaces (SVI) in the 3640 and route between them.
For instance:
Create Vlan 2,3,4
vlan database
vlan 2,3,4
exit
On Port 1 and 2 assign to Vlan 2
On Port 3 and 4 assign to Vlan 3
On Port 5 and 6 assign to Vlan 4
interface fx/x
switchport access vlan [vlan-id]
Then create SVIs for each Vlan.
interface Vlan 2
ip address 192.168.2.1 255.255.255.0
interface Vlan 3
ip address 192.168.3.1 255.255.255.0
interface Vlan 4
ip address 192.168.4.1 255.255.255.0
Then place end devices on those port and ping across to test connectivity.
HTH,
__
Edison.
Please rate helpful posts
Giuseppe Larosa Sat, 11/22/2008 - 09:46
  • Hall of Fame,
    Founding Member
Hello Edison,
this is possible only on ports of an etherswitch module or also on normal ethernet ports ?
It's not clear if the device has the etherswitch module on it or the 6 lan interfaces are made of built in + other network modules
Hope to help
Giuseppe
Edison Ortiz Sat, 11/22/2008 - 12:29
  • Hall of Fame,
    Founding Member
Correct, my assumption was based on the 3640 having a L2 etherswitch port module. I don't think you can have 6 regular Layer3 ports in a 3640, but I can be mistaken.
__
Edison.
chull6509 Mon, 11/24/2008 - 08:33
To clear up the hardware config, the 3640 came with a NM-2E2W and I added a NM-4E to it. The IOS is 12.4(10a). I am mostly interested in learning the CLI for the switch, and if the commands are very different from the 3640.
Edison Ortiz Mon, 11/24/2008 - 08:39
  • Hall of Fame,
    Founding Member
The modules mentioned are regular ethernet ports and will not provide you with the typical Layer 3 switching from a Catalyst model.
I suggest investing on a 3560 8 Port switch for full CLI experience on Layer 3 switching w/ Cisco Catalyst.
If you begin Layer 3 switching w/ a router, it may introduce more confusion in your early days.
HTH,
__
Edison.
