Cisco VPN Client and 64 Bit OS Support
Answered Question
Nov 21st, 2008
I am in the planning/testing stages of migrating users to the Cisco VPN client. Problem I have come across though is I can't find a version that supports 64 bit operating systems. I have looked through the download center with no luck. Am I just over looking a version out there? Thanks in advance.
Correct Answer by Phillip Remaker about 7 years 3 months ago
XP 64 bit is not supported, but Vista/7 are as of the 5.0.7 beta
February 18, 2010
Due to popular demand, the Cisco VPN Client v5.0.7 open beta is now available!
In addition to serving as a general maintenance release, the Cisco VPN Client 5.0.7 beta is compatible with Windows 7 & Windows Vista 64-bit environments.
A 64-bit specific compatible image is available for installation on these platforms.
Please have communicate feedback (both positive and problems) to [email protected].
Key Capabilities available for Beta Testing:
New Platform support – Windows 7 & Windows Vista 64-bit platform compatibility
Software Access: http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=281940730 (under 5.BETA)
Software is available for download by any customer with a Cisco.com SMARTnet™ enabled login.
Release Notes will be available next week via a link once the download image is selected.
Correct Answer by Farrukh Haroon about 8 years 6 months ago
AFAIK there is no 64-bit support and its not even on the IPSEC VPN Client roadmap. For more details see:
http://www.cisco.com/en/US/docs/security/asa/compatibility/asa-vpn-compatibility.html
Farrukh
Overall Rating: 4.8 (4 ratings)
Correct Answer
Phillip Remaker Fri, 02/19/2010 - 11:30
  • Cisco Employee,
February 18, 2010
tachyon05 Mon, 03/08/2010 - 15:21
great thanks.  yes i see now that as of the 2/18/10, this is available as a beta.  i will give this a try in a VM.  thanks again
cco_heerema Wed, 04/07/2010 - 03:29
This client works fine for me, just installed it on my Win7 X64 machine, and I am able to connect to all my IOS VPN's.
Thanks for pointing me out, hope Cisco will release a stable version a.s.a.p.
Kimberly Adams Thu, 04/29/2010 - 07:59
  • Silver, 250 points or more
Thank you Tomas!  I have been trying to follow this forum to see when a stable release
will come out!!!!
IAN WHITMORE Tue, 07/20/2010 - 09:34
You can also use VPNC (sourceforge) and it doesn't require the installation of a 3rd party firewall like zonealarm which only consumes memory.
