Client's roaming decision
Nov 21st, 2008
I have heard this question before from customers and have had mixed replies from Cisco and instructors at Gigawave who worked for Aironet.
Q1 How does the CB21AG using the Aironet Desktop Utilty 4.2.0.269 determine which 1242-LWAP AP to associate to? Can I debug the decision it made?
Q2. How does the Microsoft Wireless Zero Configuraiton (WZC) determine which 1242-LWAP AP to associate to? Can I debug the decision it made?
If you have a answer I'll also ask for a url reference.
Overall Rating: 4 (1 ratings)
jeff.kish Fri, 11/21/2008 - 14:40
Hi Jason!
Well, I don't have a URL reference... but there's a good reason why. The reason you aren't getting any answers out of Cisco or Gigawave is because, well, there's no good answer.
There is nothing at all about roaming in the 802.11 standards. As such, all wireless adapters have their own algorithms for determining when to roam. And companies tend to keep these algorithms secret, because it's company IP.
As far as I know, you cannot debug either Windows or Cisco client adapters when they roam. There is no way to receive insight as to why they roamed, and this is by design.
This isn't exactly what you wanted to hear, but it's how it works I guess.
Jeff
scottmac Sat, 11/22/2008 - 10:10
I pretty much agree with what you posted, but wanted to point out that Intel have (had?) settings for their wireless NICs/Drivers that let you adjust some of the roaming parameters.
IIRC it was a window / tab from their "Advanced" settings screen.
FWIW
Scott
dennischolmes Fri, 02/27/2009 - 10:44
Most higher quality chipsets have the ability to adjust roaming aggressiveness. If they don't, we pretty much recommend a newer chipset. The chipset manufacturers base their algorithms on basically 3 factors. 1. Signal strength. 2. SNR, 3. Client load on the existing AP. If the threshold for any of these are violated the client chipset goes into active scan mode and seeks a better AP. If none is found it will stay where it is. If a better AP is found the process of reassociation and reauthentication (if needed, not needed with LWAPP solutions usually) to the new AP.
George Stefanick Fri, 02/27/2009 - 18:06
I wanted to share a book i am in the middle of reading. Its "Secure Roaming in 802.11 networks"
Its a great book ... talks about the driver, chipset, clients, etc ...
Leo Laohoo Mon, 03/02/2009 - 13:48
Using the (Aironet) Cisco Desktop Utility, you can configure which AP's you want to associate in a particular order. Otherwise, the CB21AG card will associate on the AP with a stronger and stable signal.
Does this help?
jeff.kish Tue, 03/03/2009 - 13:32
Be careful about using the Preferred AP function. This forces the client to stay attached to that AP as long as possible, which can result in roaming issues.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
